Are my AFR heads too big for my combo?
Old Jan 20, 2008 | 06:25 PM
CamaroX84's Avatar
My current setup is:
355ci
Comp Cam, 230/236 duration @ .050", .510/.520 lift
AFR 195 cc heads
Performer RPM intake
Demon 750 carb
1.6 roller rockers
10:1 compression ratio
Do you think my 195cc heads are too big? I haven't really found a similar combo with those heads/cam. Thanks.
Old Jan 20, 2008 | 06:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Are my AFR heads too big for my combo?
i dont think they are
Old Jan 20, 2008 | 06:30 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
They are fine. Tons of people have 355s and 195s. Good combo.
Old Jan 20, 2008 | 06:33 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
that lil SHlT is gona revvvvv! u better be ready for 6000-7000 rpm peak power wit that cam too
Old Jan 20, 2008 | 06:49 PM
Damon's Avatar
Below 2500 she'll be a little soggy, but so will your cam. It's a reasonably well matched combo from the specs you posted. From 3000-up it's gonna rip.
If you're running an automatic I assume you will choose a converter with a stall speed to match the rest of the combo (2500 minimum, 3000 preferred).
Old Jan 20, 2008 | 06:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I'm sure it'll be fine. On bigger cams we've put 210s on 355 with no issues.
Old Jan 20, 2008 | 10:25 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The heads are not too big, it will work fine.
Old Jan 21, 2008 | 12:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Ditto's.
Old Jan 21, 2008 | 01:19 PM
CamaroX84's Avatar
Thanks for the replies. I've got a 3200 stall Edge converter.
Old Jan 21, 2008 | 05:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Pretty similar to my combo... 357ci, 200cc World heads, XE274 cam (230/236 flat tappet), 10:1 CR, 750 Holley DP, MSD ignition. Haven't tried it yet at the track, but it does run and drive pretty nice.
Old Jan 21, 2008 | 06:22 PM
CamaroX84's Avatar
Let me know when you run it Adam. I'll be running mine (finally) this summer. I'm hoping to run a 12.40 or so.
Old Jan 21, 2008 | 09:38 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
That engine should be great!
Old Jan 21, 2008 | 11:25 PM
EvilCartman's Avatar
Car: '82 Z28
Running AFR 195's on mine, runs great.
Old Jan 22, 2008 | 08:47 PM
Air_Adam's Avatar
I don't know what it will run, because I don't know if I'll be changing the gears in it or not this year (2.73s now) or if I'll just wait and put in a 12 bolt later.
I also need the driver mod, lol
Old Jan 23, 2008 | 02:39 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Great setup for your combo, the compression will help keep it from being too soggy down low with all that duration but i agree that around 2500-3000 the cam should come on very hard. I have a cam with 235 duration and much less compression and right at 3000 it just screams.
Old Jan 23, 2008 | 02:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i'll be using those AFR 195 heads on my 383 build and a larger roller cam than that 230/236. Those 195cc AFR's really fit the bill for hot 350's and most all 383 builds as well as mild to street/strip 400's.
Old Jan 23, 2008 | 08:16 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
When I was a 355....I ran the same cam I have in my 383 the 276hr 224/230 with AFR 195 heads and no problems...I had issues with other things like road bearings....which led to the 385 i currently have with the same cam
Old Jan 25, 2008 | 06:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Damn near the same combo I have been running for the last 7 years or so. Runs great, and yes..she will scream up top. Just sold my heads to step up to the new 195 Eliminators.
Old Jan 28, 2008 | 02:37 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
355ci
AFR 195 cc heads
Demon 750 carb
1.6 roller rockers
I'm going to be running a very similar combination with the motor that I'm currently building. I talked to someone at AFR about a week ago and they recommended the 195 Eliminators based on the specs I gave (Like I said, very close to yours. Same trans, rear end ratio, and I also plan on using a COMP XR282). They told me to step up to 1.6 rockers, but you already have that on your list.
Old Jan 28, 2008 | 02:59 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I am running the AFR Eliminator 195s (62 cc chambers) on a stock displacement 350 short-block. Check my sig for other mods; there is no lack of power anywhere (that a modded TPI can support) in the RPM range.
Bill
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
