CAN ANYONE HELP
Old Jan 28, 2008 | 03:05 PM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
CAN ANYONE HELP
just changed my blown 700r-4 for a new one and fired it up Friday on the lift but when i put it in drive the wheels moved like it was suppose to but it just boggs down and cuts off. when i gave it some gas the tires spun faster and the car stayed on for a few seconds longer but still bogged down and shut off. my friend an ASE certified master mechanic said since the battery has been out for more than a month the car has to "learn how to idle again" and said he would bring his programmer with a idle trainer Wednesday. Could this be what it is? any other suggestions .............Thanks
Old Jan 29, 2008 | 07:14 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: CAN ANYONE HELP
My bird sat for 3 years straight once with no battery, it never needed to "learn how to idle again". But then again I am not mechanic what do I know.
Old Jan 29, 2008 | 07:24 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Re: CAN ANYONE HELP
Yeah my Camaro spent 4 years in a pasture with the battery still hooked up...put in a new battery and some gas and cranked right up and drove fine.
Old Jan 29, 2008 | 07:35 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: CAN ANYONE HELP
lol theres no learn idle on these cars sorry...
Old Jan 29, 2008 | 07:46 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: CAN ANYONE HELP
Did you get it full of fluid (Torque Converter first then install tranny, fill tranny, run tranny, top it off)
Sounds like your torque converter may be holding... do you have trouble with braking?
Its not idle lol... I just ran my car (stored without battery) since november on sunday.
Did you change the torque converter out for a new one?
Old Jan 29, 2008 | 09:15 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: CAN ANYONE HELP
Never heard anything like that in 25 years.....
Old Jan 31, 2008 | 10:26 PM
fignewton's Avatar
Car: 1984 Z28
Engine: .030 over 350 4 bolt .480/292 cam
Transmission: Tremec TKO 600
Axle/Gears: 3.27:1 posi
Re: CAN ANYONE HELP
There are plenty of cars that have to "relearn the idle" It's just that most of them are FORDS! You shouldn't really have to worry about that on your car.
