Power steering pump pulley
Old Feb 9, 2008 | 11:00 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Anybody know how to get the pulley off the PS pump? I know it has something to do with the allen wrench hole in the end of shaft, but beyond that I'm lost and haven't had any luck with chanel locks. I've got a good pump W/the wrong bracket and a bad pump W/the right bracket! Any help would save money and time if I could just change them.
Old Feb 10, 2008 | 01:44 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Power steering pump pulley
The pulley is pressed on. You need a special tool to remove and reinstall it. You can get a Cheapo Chinese Hop Sing made PS pully remover/installer kit for around 20-30 bucks. Some auto parts stores will rent them for free.
You'll never getting the pulley off with a channel locks. The press fit is a few thousands. Its on there pretty tight.
Old Feb 10, 2008 | 12:28 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Thanks for the info. I've had everything else apart on a car but the PS pump.
If it wasn't so dam cold here in Indiana, I'd just hit the local U/pullit and grab me a pump. What get's me is why the end of the shaft has a hex head hole?
That's like having a flat tip screwdriver slot on a head bolt!!.
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 12, 2015 11:33 AM
