Ventilator Valve Assembly
Old Feb 9, 2008 | 11:00 PM
831chevyman's Avatar
Car: 67 Camaro/91 Camaro
Engine: 350/3.1 v6
Transmission: M22/stock
Axle/Gears: 3.73 GM 12 Bolt/stock
Hey i have a 91 camaro v6 and i was recently changing out the fuel pump... i ran into a problem when i came to disconnect the fuel lines. i was removing the ventilator valve assembly and broke off the plastic that the hose attaches to on the assembly, so now i have no way of putting it on besides buying a new one or pulling one off the junkyard. i was wondering what this piece did and what it would do if it was not attached. i recently purchased the car so im still trying to find out how the car runs since it had been sitting with a bad fuel pump for awhile. thanks any info would be great
Old Feb 12, 2008 | 07:45 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Ventilator Valve Assembly
you talking about this.
https://www.thirdgen.org/forums/atta...082705-003.jpg
If so check out this thread:
https://www.thirdgen.org/forums/tech...ight=vent+tank
Old Feb 13, 2008 | 02:09 AM
Engine: 350/3.1 v6
yea thats the part... do you know if it does anything besides just vent the fuel tank or is that it... do you know if anything will happen from not having it on
Old Feb 13, 2008 | 08:37 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
AFAIK, it doesn't technically "Vent" the fuel tank. I suppose it might if a ridiculous amount of pressure built up, but it lets the tank suck air in when it needs it, IE, using fuel, or vapor condensing due to colder temperature.
Old Feb 13, 2008 | 09:37 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
I can tell you one thing about this valve. If it is bad you will fail california's evap part of the smog test.
Old Feb 13, 2008 | 06:57 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
You need it for the car to run. The gas cap is not vented. So the tank will collapse if the vent is plugged. The valve also allow a little pressure to build up in the tank from evaporation. This evaporation is collected in the canister.
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
