Does my Camaro have a 2 bolt main or a 4 bolt main?
Old Feb 15, 2008 | 10:59 PM
hawthorne89415's Avatar
I will be honest. I was never thought how to fix cars, So when you talk about an engine to me its like speaking another language, I don't know what you just said. But I just bought an 89 IROC-Z and I am looking for an engine to have my mechanic put it in for me. Now does it make a difference whether or not i buy a 2 bolt main or a 4 bolt main engine.
Old Feb 15, 2008 | 11:12 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: Does my Camaro have a 2 bolt main or a 4 bolt main?
Get the 4 bolt 350 block if want over 450 hp, reving past 7 grand, nos, turbo, ect....Or if you have the extra money so you can say you have one. 2 bolt blocks are fine for any thing else, I have them in my car and use many stock GM parts which will support 450 hp for a long time. My 4 bolt block is for racing only with 630 hp.
Old Feb 16, 2008 | 02:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
For most street cars, a 2 bolt block should be fine. If it's going to wind up costing about the same, I'd go for the 4 bolt block. There are other differences in the blocks too though, such as roller vs non-roller lifters and fuel pump hole. Late model blocks that came in fuel injected cars won't have a hole to mount an engine driven fuel pump, which means you'd have to use an electric fuel pump, even with a carbureted setup. It's not the end of the world, just one more thing to set up. If you're planning on keeping the fuel injection, then it doesn't matter.
Old Feb 16, 2008 | 02:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 2 bolt block is fine.
Old Feb 16, 2008 | 03:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Lets take a step back here. Is the car running now? Does it NEED a new engine? Puking a bit of blue at startup can be as cheap as $40 to fix for example. No sense dropping upwards of $4000 just yet.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
