rubber fuel lines with hsr
Old Feb 16, 2008 | 01:53 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay I just installed the HSR and i had to do my own fuel lines. Holley said to use high pressure rubber fuel lines, but fuel pressure rubber hoses are rated to 45 psi. I will run probably like 50 psi though. DO they underate the fule lines. I will one day do all braided lines, but i have to order custom fittings to fit the lines from the fuel tank. I dont know if anyone is aware but the ones from the tank have like double flares. Any ideas would be great
Old Feb 16, 2008 | 08:48 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Re: rubber fuel lines with hsr
My HSR has braided steel lines from the metal line inthe engine compartment to the fuel rail. I wouldn't use rubber fuel lines, its not worth setting your car on fire.
Old Feb 16, 2008 | 10:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://store.summitracing.com/partde...5&autoview=sku
Working pressure 50 psi, max pressure 175 psi.
Braided for fuel injection would be the smart way to go.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
