How to loosen steering column
Old Feb 16, 2008 | 02:08 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I was on the way to change my Ignition Switch today, and its seems hard to find it behind all the cables and **** thats under there..
The ignition switch is it on the topside of the steeringcolumn somewhere around that arrow ? or ? havent really found it yet.. needed to check with you guys first
The thing is that the steering column has to be lowered , I tried to remove the 2 bolts that holds it up but I couldnt lower it so much, is there anything more I need to loosen / remove before I can get to the ignition switch ?..
and I got TILT on my steering, and then its one right ? (steering with TILT) : http://store.summitracing.com/partde...5&autoview=sku
bacause the 95 one (is for vehicles without tilt) :http://store.summitracing.com/partde...5&autoview=sku
So I need to go back to the shop and get my US95 ignition switch changed to US105 .... because I have steering with tilt...
this is the one I got:
its the US95 and it seems like its for the non tilt models (it says so in the information in the box. havent checked it against the stock one yet but..)
Is there anything else to think about before I replace it ?..
Anyone here that changed it and maybe have som pictures ?
Last edited by Theking; Feb 16, 2008 at 02:16 PM. Reason: adding more info and pictures....
Old Feb 16, 2008 | 04:13 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Re: How to loosen steering column
When I lowered mine there were 2 bolts on a shinny metal bracket that held it up. If you are sitting in the seat they are about where the tops of your shins are at. After I took those out the coloumn dropped to where the steering wheel rested on the seat.
Old Feb 16, 2008 | 04:21 PM
Theking's Avatar
Car: 1989 IROC-Z
Yeah I removed those to bolts, but it didnt wanted to go down all the way to the seat.. I didnt want to push it down, dont want to brake something like the steering or brakeswitches down there..
Old Feb 16, 2008 | 06:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i usually almsot always pull the column out when replacing and ignition switch
if you wont pull the column then rmeoving the seat real quick will allow the column to come down real far so as long as wiring and such allows it
gotta do what ya gotta
Old Feb 17, 2008 | 03:45 AM
Theking's Avatar
Car: 1989 IROC-Z
Yeah there isnt a risk of breaking anything if I do it gentle and removing the rubber sealing in the firewall to ? its just those 2 bolts that holding it then ?
Gotta get the switch replaced with the right one, the us105 first before I remove anything..
Thanks for the help
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
