Starting issues
Old Mar 3, 2008 | 06:40 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Starting issues
Sometimes I turn the key and just get a click from the starter. Battery is old but shows 12.4 volts with a meter. This happened on the old engine as well. This is a new engine, new starter, new everything.
Could the battery's amps be low? Im lost....
Old Mar 4, 2008 | 12:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check your voltage on the start wire at the solenoid. You could be losing significant voltage through the chain - neutral safety switch, ignition switch, bulkhead connection, etc. I finally just installed a remote solenoid and said goodbye to the problem.
Old Mar 4, 2008 | 05:00 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Starting issues
Yup, that was the problem. I direct connected the wire to the battery and shazam.
How do I bypass all that stuff though? Might be easier to just wire up a push button start, which i wouldnt mind.
Need a new battery too, my A1000 is really draining me. Windows are slower than normal (snails), and I hear the pump slow when I turn the lights on.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
