Poll: Torque or no torque?
Old Mar 18, 2008 | 01:43 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I've got a small block on my engine stand. It has roughly 10K on a pro rebuild and I'm fixing to bolt on an Edelbrock high rise and carb and add a set of headers. I'm going to keep the stock cam (flat tappet Hyd). My Q. is, while I have the pan off, Do you think it would be a good idea to recheck the torque on the rods and main caps, or just leave them alone? It's a 4 bolt main and I plan to keep it under 5k rpm.
Old Mar 18, 2008 | 02:07 AM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
Re: Poll: Torque or no torque?
if your sure it was a good rebuild then don't mess with it.
Old Mar 18, 2008 | 07:26 AM
Agreed, leave them alone.
Old Mar 19, 2008 | 12:43 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
That's what I was thinking. I was so lucky to find the builders tag on the block and was able to find them on the web. I found out everthing that had been done to it. Thanks
Poll results:
For:0
against: 3 (counting me)
Old Mar 19, 2008 | 01:30 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
dont touch unless you plan to rebuild.. messin with it may "loosen" the static hold that the bolts have from breakin..
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
