Hardened valve seats?
Old Mar 22, 2008 | 06:33 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I have a extra 186 head laying around and was wondering if there is a way to just look at the valve seat and tell if it has been hardened? I have another set of 186's that are ported and polished and I was going to go ahead and port and polish this extra one so I have a spare head (never know). The guy I bought the set from said they had hardened seats but I would like to be able to check for my self.
Old Mar 23, 2008 | 10:21 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Hardened valve seats?
If it has had exhaust seat inserts put in it, then it is ok with unleaded gas.
It is very unlikely that it has hardened seats because they were only made in '69 and '70. The hardened seats made their debut in 1971 in stock heads and are easy to spot.
...They are swimming around in big 76cc chambers. (74cc for 307s)
The 492's are the only ones I know of that were produced after '71, had the small combustion chamber, and may have hardened seats.
So the general rule of thumb for early stock heads:
1.small chamber, leaded gas, soft seats.
2.big chamber, unleaded gas, hard seats.
Old Mar 23, 2008 | 10:29 AM
The factory used induction-hardening, as opposed to inserts.
If they're cleaned up, the seat area will be sort of darkened and blue, for maybe ¼" around the seat.
Otherwise, if somebody else installed replacement seats, they're probably hardened enough for modern fuel.
Old Mar 23, 2008 | 03:02 PM
sweetaq's Avatar
Car: 1982 Z28
Yeah I am pretty sure the seats have been replaced. I doin't think the previous would have gone through the trouble of a port and polish and having screw in studs and guide plates installed and not have had the seats redone. But I would like a way to be sure. I guess I will take it to the machine shop and see if they can tell?
Old Mar 23, 2008 | 05:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It will look like a piece has been pushed in there. You should be able to see a parting line around the valve area. Get a good close up picture (macro!) if you want, and post it up here for the peanut gallery to comment on
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
