CA Smog Check Pre-Test: FAILED
Old May 4, 2008 | 02:04 PM
  #51
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: CA Smog Check Pre-Test: FAILED
First of all, get a new fuel cap. If your cap isn't sealing, then it's letting raw gas fumes into the air. HC's.....
I can't see 9° timing helping pass the e-test either. Changing my timing even 1 degree makes a noticiable difference on the idle. Maybe it's because I have a PCMForLess chip that's probably cranked up on the timing (knock sensor is disabled). I do know that my car will ping at 8° on premium gas at WOT in 2nd and 3rd. Also when the car is running at 220°F plus......I changed the timing to 5 and then 6 and all is better now.
About the O2 sensor. I put a brand new Bosch in the car after having the engine thoroughly cleaned and rebuilt. Ran pretty good...After about 3 weeks of driving it like that, I took out the Bosch and put in an AC Delco O2 sensor instead. Cost me $75, but the car ran smoother all over with it. It wasn't running bad with the Bosch. But it just ran better with the AC Delco.
Old May 5, 2008 | 09:31 PM
  #52
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
I passed!!!
Code:
            %CO2  %O2      HC(PPM)           CO (%)        NO (PPM)
Test  RPM   MEAS  MEAS   MAX AVE MEAS   MAX  AVE  MEAS  MAX  AVE  MEAS   Results
15mph 1493  13.6   1.5   126  41  91    0.79 0.13 0.61  1097 399  892    PASS
25mph 1513  13.8   1.4   101  29  65    0.59 0.11 0.30  927  332  681    PASS
All I've done since the pretest is:
1) Put the original ECM back in.
2) Put in a new AC Delco O2 sensor (to replace a Bosch O2 sensor)
3) Replaced a few hoses in front of the carb and from the PCV valve to rule out any vacuum leaks there.
4) Oil change, oil filter, pcv valve, new AC Delco RT45S spark plugs
5) I put in about 1/2 bottle of the CRC Guaranteed-To-Pass gas additive to 1/2 tank of 89 octane gas (but I didnt use up all of the 89 oct. gas in the tank before I filled up with 91 octane gas before the test) (the pretest that I failed was done with 87 octane gas)
Old May 7, 2008 | 02:04 AM
  #53
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Congratulations! Now you can bring it to our next SoCal Thirdgen meeting on Sat June 7th!
italiano67
Dec 11, 2016 09:21 AM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
