Head bolt question
Old Mar 27, 2008 | 04:04 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Head bolt question
Hey I am putting a set of 416 heads on my L98 engine. I can just use whatever bolts are recommended for the L98?
I was looking at these GM performance head bolts, are they any good? Another thing, it says it is a "set" does that mean it has bolts for both heads or just one?
http://store.summitracing.com/partde...9&autoview=sku
Old Mar 27, 2008 | 06:07 PM
Re: Head bolt question
Yup.... stock SBC head bolts have been the same for all stock heads (with only a VERY FEW exceptions), since 1955.
The pic shows a full engine's worth: 14 long ones, 16 short ones, 4 medium ones. FWIW. Maybe you could look it up in the GMPP catalog?
Old Mar 27, 2008 | 06:37 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Old Mar 28, 2008 | 09:14 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
That is a full set of bolts but make sure to put sealant on the bolts that will hit the coolant jackets. The stuff on the threads from the manufacturer doesn't always seal properly and there is nothing worse than coolant leaking up through the bolts. Any non hardening thick thread sealant normally works well
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
