Reverse Coolant Flow
Old Mar 29, 2008 | 09:41 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
what would be the benefit of putting a reverse flow water pump on a gen I sbc? if any...i belive napa makes one for gen i blocks, would this help increase compression safely on pump gas to a little less than 10.5-11? and would it be a problem with it also running throuhg the intake (which i know it doesnt on a gen II or III)? Just a interesting thing i read when reading about the procharger serpentine set up, and wondering if it would have a similar effect as a gn II or III...
Thanks.
Old Mar 29, 2008 | 10:54 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Reverse Coolant Flow
how would the thermostat work?
Old Mar 30, 2008 | 02:19 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Nope, not how it works.
Reverse rotation means you need to spin it backwards, ie with a serpentine setup (1987-1995) rather than a v-belt setup (pre 1987 or so). It still moves coolant the same direction through the engine.
LT engines are the only reverse flow engines, and you cannot simply "mod" an engine to reverse the coolant flow, needs a complete redesign.
Keep in mind the LT engines were succeeded by the LS engines, which have "normal" coolant flow. That should lead you to believe that the reverse flow wasn't the end all eh?
Old Mar 30, 2008 | 08:36 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
I always thought the LS engines had reverse coolant flow...oh well just a thought...it would be nice though...
Old Mar 30, 2008 | 12:44 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Reverse rotation didn't start until '88. that motor in mine is from an '87 IROC and uses a standard rotation pump.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
