So get this
Old Mar 30, 2008 | 01:38 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
So get this
After searching around my car, I hav realized teh previous owner left a sensor out just sitting around. I didnt think much of it because the car ran fine without it. Anyways I now realized that it is my coolant temp sensor. So I have been drivin for a while now with the temp sensor just lying by the manifold area, sort of hidden.
Should i go get a new one just in case?
Old Mar 30, 2008 | 02:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: So get this
So what, you don't have a bulb in your check engine light or what? !
It would have been running fairly rich all the time IIRC. Plug it in and put a bulb in the check engine light and pull the codes, see where you stand.
Old Mar 30, 2008 | 02:09 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: So get this
LMAOO How did you know??? I had a ******* own m ycar before. I would have a 10 second camaro if I didnt have to completely redo everything he did. I have no check engine bulb, he even electrical taped it. And yes my car always ran rich, always.
What is the IIRC thing too. I feel like a noob
Old Mar 30, 2008 | 07:00 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: So get this
IIRC = If I Remember Correctly?
I believe that's it, took me quite a while to figure that one out LOL.
Need to have a page for all the slang terms LOL.
Old Mar 30, 2008 | 07:06 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: So get this
True story.,
Old Mar 30, 2008 | 07:14 PM
Re: So get this
There's a bynch of those lists, all over the Internet.
Here's one.
http://www.netlingo.com/emailsh.cfm
Old Mar 30, 2008 | 07:30 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: So get this
hey sofa I really need some help. You have any efi knowledge under your belt?
I know you have a lot of good ideas and stuff
