Distributor wear.
Old Mar 31, 2008 | 05:20 PM
vdubnut's Avatar
Distributor wear.
just wondering how much side to side play a distributor shaft should/should not have.
I have a 91 suburban 350 TBI and I'm trying to track down a stumble in the engine when i let off the throttle and when i just barely push the throttle. I replaced the cap and rotor less than 2000 miles ago and they already look corroded. i wiggled the shaft back and forth and there was some movement. not a ton but maybe 1-1.5 mm. is this normal? also are there distributor bushing rebuild kits out there if this is something i need to fix?
thanks in advance...
Old Apr 1, 2008 | 09:28 AM
vdubnut's Avatar
Re: Distributor wear.
any thoughts anyone? one other thing....i replaced the cap and rotor with a MSD set from checker. it looked like there was a tiny bit of interference of the plastic on the top of the rotor with the cap somewhere....a bit of plastic you could tell had rubbed something.
Old Apr 1, 2008 | 10:18 AM
Damon's Avatar
You mean side-to-side movement? No, there should be none (only a few thousandths of an inch). Up and down play in the shaft is farily generous in most factory distributors, however, and generally doesn't cause much problem.
Old Apr 1, 2008 | 11:24 AM
vdubnut's Avatar
thanks for the reply...
so if i have more movement than a couple thousanths then do i look to rebuild or replace? if so...what is a good replacement brand?
Old Apr 1, 2008 | 06:19 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
My TBI truck distributor gear went just after 100k ...if you have play, its going bad, replace it... if you want to upgrade, get a better than stock brandname distributor
Old Apr 2, 2008 | 10:16 AM
vdubnut's Avatar
so what "better than stock" aftermarket dist are popular? do they connect right up to the factory wiring so its just a matter of installing and setting base timing?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
