quick question about tune up
Old Apr 1, 2008 | 04:43 PM
littlesk8cracke's Avatar
this weekend im doing oil and filter, plugs and wires, cap and rotor, transmission drain and filter, rear axle drain and refill, fuel filter, and draining the coolant system. so i need to know some types and amounts for some things as this is the first time im doing them
how much transmission fluid and what kind?
how much coolant and what kind?
how much rear axle fluid and what kind?
iv done oil so i know about that, and i dont need anything else to do fuel filter and the ignition stuff. so could someone help me out? thanks!!!
Old Apr 1, 2008 | 04:47 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: quick question about tune up
Get one whole jug of coolant non deluted. I use peak antifreeze, I like it alot. Then whatever is not filled up put water in it. The transmission part, make sure you do not overtighten the bolts on the transmission or you wil leak. I am a veteran at that. lol
ATF transmission is fine if you have a auto tranny. IDk if its same for a manual.
Rear axle oil i use 75w-90
Old Apr 1, 2008 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year is your car?
What engine do you have? V6? V8? TBI? Carb?
What transmission do you have?
Old Apr 1, 2008 | 09:23 PM
its an 84 z28 with a 91' 350 block. 700r tranny
Old Apr 2, 2008 | 06:36 AM
so one jug of antifreeze, how much transmission and rear axle fluid?
Old Apr 2, 2008 | 11:27 AM
five7kid's Avatar
Dropping the transmission pan and changing the filter will require 5 quarts to replace. However, the transmission contains a total of 12 quarts - see http://www.amsoil.com/faqs/ATF_and_F...Procedures.pdf (particularly Step 13) for how to replace it all.
The differential holds 3.6 pints.
The cooling system holds 17 quarts if you have AC. A 50/50 mix will require slightly more than a gallon of antifreeze, but a gallon will get you close.
Old Apr 4, 2008 | 04:19 PM
could this be answered real fast, like in less then an hour? do i need gasket sealant for the new tranny and rear axle gaskets?
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
