looking for a mild cam
Car: 1982 Trans Am
Engine: Junk 305
ive got a 305 carbuerated completely stock except for LT Hedman hedders. i want to step up to a mild cam. but i dont know the first thing about it. nothing too special, just something to give me a little more umph on the street and the strip.
Transmission: 4L80E/4L80E
A Comp XE258 or XE262 would be a noticeable difference.
Have you done anything to or have plans for the exhaust? Air cleaner?
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Re: looking for a mild cam
Look at these Comp Cams.
CS XE249H-12, (Mild Cam) Flat Tappet.
CS XE256H-12, (Flat Tappet, similar specs to GM LT1 709 roller cam)
CS XE262H-14, (Flat Tappet) the one that five7kid mentioned. May need to check with him on the Stock Valve Springs with this cam.
