aluminum 1.6 roller rockers stock springs?
Old Apr 6, 2008 | 10:30 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i have a set of 1.6 gm performance roller rockers i would like to install them on my l98 with stock cam and springs will it work fine with the stock springs also how long to aluminum rockers usually last?
Old Apr 6, 2008 | 10:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: aluminum 1.6 roller rockers stock springs?
yes it should work but check to see how much clearance you have with those rockers and the valve cover. you may need to cut some baffles out of the stock valve covers if your using stock valve covers
with stock spring pressures, aluminum rockers will last for awhile if they are quality. I've heard they will fatigue under high spring stresses and lots of street driving. Aluminum is abit more fatigue prone than steel but alot of ppl are using aluminum rockers just fine. Some articles i've read say its just a myth that street driving hurts aluminum rockers. So i think you will be fine
Old Apr 6, 2008 | 10:44 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i have aftermarket chrome covers you have any problems with your rockers i think you got the roller tip ones right? You said yours ran alittle leaner with the rockers. Think ill rejet the carb too
Old Apr 6, 2008 | 10:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you'll have to see about the leaning issue. mine i wasnt sure what happend. I was around 12.5 to 1 before the injector swap and 1.6 rockers. i think the injectors were not spraying right. Brought me up to 14.5 to 1 on the dyno. but that little extra lift may have got some more air in there, so it could have made it abit leaner. I thought the MAF would have compensated alittle for that so who knows
But i have had no problems other than that. I had comp mags, roller tipped
midge54
Dec 27, 2019 04:14 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
happyhapka
Aug 15, 2015 04:42 PM
