Check Engine...
Old Apr 8, 2008 | 11:23 AM
Locke_Seven's Avatar
Check Engine...
Got a question for whoever can help. I have a 91yr, V8-305, TBI camaro. I recently replaced my throttle position sensor (for a problem that I had but it didn't fix it that is another story) and now I'm getting an error code 21 on my check engine light which means 'High voltage at throttle position sensor' has anyone seen this before? Is it a faulty sensor out of the box? Any ideas of where I can go next?
Thanks,
Jeremy
Old Apr 8, 2008 | 12:09 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Check Engine...
Does your tps have slots or just holes? If slots it needs to be adjusted to .54 volts. If just holes then check volts if bad, check how tps is installed. otherwise replace.
Old Apr 8, 2008 | 12:33 PM
Re: Check Engine...
The TPS only has holes, I was surprised by this I'm used to the ones with Slots so you can adjust them. I will have to check the voltage that is a big help.
Old Apr 9, 2008 | 04:27 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Check Engine...
The mafs seem to have the adjustable and the sd the fixed. The sloted type can be used on both. Or file open the holes a little to tweak it in.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
