Are these the right rockers?
Old Apr 10, 2008 | 01:19 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I am putting in a new set of dart pro 1's with a weiand stealth intake and speed demon 750 carb with 1" spacer. I also will have a comp cams 234/234 cam. Im not too sure botu the cam specs right now, but I need some 1.6 rockers. Im going to be in a ballpark range of 450hp on motor when im done, and a 150 shot will be on demand.
http://store.summitracing.com/partde...6&autoview=sku
Will those rockers stand my power that i will be giving the motor?
Anyone reccomend a good set of pushrods for the price too?
Old Apr 10, 2008 | 04:00 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Are these the right rockers?
those rockers will probably outlast your motor.. those are one of the best rockers for the money.. as for pushrods, these are good for the price.. heat treated, chromemoly, one piece, etc.. just make sure you get the right length.. stock is 7.800" but some heads require a bit longer to maintain valvetrain geometry..
Old Apr 10, 2008 | 10:42 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Alright. Ya im not looking for my motor to last long. Lol Im building a forged 383 setup, but i need a car fast and this is the stuff in my hands. I juts wont beat it to the ground like i use to
Old Apr 10, 2008 | 11:35 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Make sure about the rocker stud size. Some heads are 7/16 instead of 3/8.
Old Apr 10, 2008 | 02:54 PM
bigzeke's Avatar
would that be a borg-warner 9 bolt ,yopu havent blown that thing yet ,not being critical just reading -----------------------bigzeke355cid 4.10 10bolt 92bird
Old Apr 10, 2008 | 03:14 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have done pretty much anything there is to blow. minute and half burnouts, drag race every week. you name it. It drives well actually. I will be going from front to back to get my car where I want it.
Anyways will the stud size be in the specs of the heads. I am buying them from summit. They are the dart pro 1 platinums. 200cc 64combustion chamber 2.02 intake blah blah blah
Old Apr 11, 2008 | 09:41 AM
bigzeke's Avatar
most likely those screw in studs will be 3/8 go to dart im sure the have the complete specs but im curious those are some serious heads and they love roller cams i noticed you said cam only has 234 degrees of duration with the right converter those heads will make some serious horses but id step up on the duration to really get the air to fill those runners and cylinders however it should still be stout ----------------------------------big zeke355cid 92bird
Old Apr 11, 2008 | 09:47 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya that cam actually fell through. My buddy isnt gettin the car, so im buying a nitrous cam. I cant wait. I will have the lower end fully forged too.
Old Apr 11, 2008 | 11:36 AM
bigzeke's Avatar
look at the new comp thumper hydraulic rollers they have a more agressive exhaust profile which a good nitrous cam will have more exhaust lift and they sound bitchin go to comp cams .com and you can hear the thumper and mother thumper -----------------------big zeke 355cid92bird
Old Apr 11, 2008 | 01:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Pro Magnums are GREAT rockers - absolutely bulletproof.
I would HIGHLY reccomend getting the longer (1/8" or so) ARP rocker studs though, as the huge bearing in these rockers don't allow for much thread engagement by the poly lock on a stock length stud (you'll see how the set screw in the poly lock goes WAY down into the poly lock when you set it - it should be near flush with the top). I broke one stud because of that. Put the longer ARP studs in there and never a problem since.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
