flexplate?
Old Apr 11, 2008 | 07:02 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
flexplate?
i did a swap froma 84 305 ho to a early 70s 350 well it has a bad vibration,first off i used flexplat from 305 and put it on the 350 i didnt know or realise the weight thing but i have the flexplate originally off the 350 and yes it has weights on it ,so is this whats causing my vibration? before i pull trans out again? the flexplate from the 305 has no weights but is conserderably smaller in diameter then 350 one
also will the 305 starter work with the 350 flexplat? it being a diff diameter?
Old Apr 11, 2008 | 07:26 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: flexplate?
Yes you need to run a 350 flexplate. Also, you will need a 153 tooth.
Summit has these.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
