hydraulic roller cam limitations?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
can someone edumacate me here? what are the limits of a hydraulic roller cam as far as lift? what issues do you run into with a cam with about .600 lift? is it valve float or something like that?
I thinking about upgrading my cam and i would like to stick with a hydraulic roller if its possibly/practical
thinking about maybe a CS XR300HR-10 with 1.6 rockers
it would be for a 408 with 10.44 compression
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: hydraulic roller cam limitations?
.600" lift or there abouts is no problem with todays valve trains. You just have to make sure you have the right components to match your cam. Another deciding factor will be how high you want rev your motor.
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
