Fuel pump
Old Apr 15, 2008 | 08:38 PM
neb84camaro's Avatar
Car: 1984 camaro F41
Fuel pump
I am buying a new fuel pump for my 84 camaro it has the 305. I dont know anything about them. what does gph stand for? just wandering what im looking for.. thnx
Old Apr 15, 2008 | 08:52 PM
91chevywt's Avatar
Re: Fuel pump
gph=gallons per hour=the pumps ability to move fuel. If you go to a parts store, tell them your year, make, model, and theyll probably ask if its tbi, tpi, carb. I dont know what you have, but they'll be able to help you out. Unless your looking for aftermarket..like if you have mods. But it sounds like your probably stock
Old Apr 15, 2008 | 09:01 PM
Re: Fuel pump
i have carbuerated and want aftermarket. the only mod that i have is headers.
Old Apr 15, 2008 | 09:06 PM
91chevywt's Avatar
Re: Fuel pump
when you say aftermarket, do you want mechanical or electric?
Old Apr 15, 2008 | 09:15 PM
Re: Fuel pump
Well i dont know much about fuel pumps but I'd much rather go mechanical. just becouse i dont like dealing with electric crap. is there a def. advantage of either?
Old Apr 15, 2008 | 09:23 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Re: Fuel pump
You will have -10 Hell installing the electric.. But in my book, mechanical was always more reliable.
John
Old Apr 15, 2008 | 09:24 PM
91chevywt's Avatar
Re: Fuel pump
well, mechanical is engine driven,so, in theory electric would be less of a paracitic load, even though a mechanical pump wouldn't put much load on an engine anyway. Electric pumps also will put out much higher pressure, which is why theyre used with fuel injection. For your application, you would be best with a stock replacement mechanical pump. A mechanical pump is much easier to replace when it fails, since it's right on the front of the block. An electric pump you will have to drop the fuel tank, which means disassembling the whole rear end of the car. Why do you want to go aftermarket? You wont be gaining any power or anything. The system requires a specific pressure, for your system you need somewhere around 5-7 psi which isnt much. Any more and you will run really rich. My 79 camaro came with an electric pump installed, but it totally doesnt need it. Its actually pretty noisy.
Old Apr 15, 2008 | 09:36 PM
Re: Fuel pump
Well thank you a bunch. I really didnt have much of an idea. i just figured aftermarket was the way to go. but i guess not. thank you.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
