Vortec heads is there a difference between 350 and 305?
Old Apr 20, 2008 | 08:59 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
Ive been searching for vortec heads for my 305 and the casting number ive been told that will work is 12558060. They are 1.94/1.5 with 170cc. Is there a difference between a set of vortec heads with the same intake/exhaust of a 350 engine. Would that even bolt onto a 305?
Old Apr 20, 2008 | 09:52 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Vortec heads is there a difference between 350 and 305?
the ending digits for the casting are 062 and those are from the L31 350... they will bolt right up to a 305
Old Apr 20, 2008 | 10:31 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
350 heads have larger chambers which significantly affect the compression ratio.
Old Apr 21, 2008 | 12:50 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The good 305 vortec heads have 1.84/1.50 valves, the same ports as the 350 heads, and a 58cc chamber. They have a casting number ending in 059.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
