rear end popping
Old Apr 21, 2008 | 08:05 PM
wjiroc86's Avatar
Car: 1989 RS
Engine: 305 tbi, junk, freakin slow!
Transmission: 700r4... holds up =]
rear end popping
my rear end started making a popping noise and squating more to the right side, when i launch it hard. any ideas, any common problems?
Old Apr 21, 2008 | 09:05 PM
Vader's Avatar
Re: rear end popping
Check the control arms and torque arm. Check the track bar (Panhard rod) and brace. Check the spring mounts. Check the universals. Something is probably out of line.
Old Apr 22, 2008 | 10:48 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
GM Posi units need to have a special GM lubricant additive. Without it they will bind up and pop when going around corners.
Old Apr 22, 2008 | 11:45 AM
wjiroc86's Avatar
Car: 1989 RS
where does that go and does my car have it? cause it is when i launch and take hard turns
Old Apr 22, 2008 | 12:00 PM
SmokeDiver85T/A's Avatar
Possibly sway bar end links even
Old Apr 22, 2008 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It goes in the gear lube. Same fill plug. If you don't know when the gear lube was last changed, now would be a good time to do it (regardless of whether that's what's causing your symptoms).
I'd say you also need to check your upper shock mount. They are known to break loose (mine did on the right side).
Old Apr 23, 2008 | 09:35 PM
wjiroc86's Avatar
Car: 1989 RS
thank you guys for the help gonna check the shock tomorrow, because they put new shocks on it before i got it.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
