tpi to carb fuel pump wiring
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well i did the tpi to carb swap awile back and left the computer in now i would like to run the fuel pump on a switch so i can remove the underhood mess. I bought a jegs relay kit i plan to run a 12 volt power from the battery to relay then from there run a wire to the toggle switch and another to the factory fuel pump power wire which is really small will have problems splicing the jegs 12 gauge wire to the factory wire?
Transmission: 4L80E/4L80E
If you remove the ECM harness, that's 90% of the "mess".
You'll need some way to lock up the TCC.
Other than that, run new copper for your fuel system electricals.
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: tpi to carb fuel pump wiring
Thanks for any help.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
