mech fuel pump bolts
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
anyone have any idea what type thread, size and length is needed to mount my fuel pump onto this 383, and are they available at the hardware store or do i have to go to a salvage yard.
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: mech fuel pump bolts
I think they are 3/8x18 or 5/16x18, not sure of the length.You should be able to get them at any parts store. A speed shop will probably be able to get you the correct bolts too.
Car: 92 camaro rs
thanks for the reply, i can measure the length in the morning and pick up both sets, hopefully one or the other will work, thanks again
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
We're talking mounting the fuel pump to the plate, or the plate to the block?
I'd guess 5/16NC. They have undersized heads too. Not sure if a normal sized head would work, allen capscrew would probably fit. Come to think of it, it might be 3/8NC though (3/8-16).
The ones for the plate to the block i'm pretty sure are only 1/4-20 though.
Transmission: 4L80E/4L80E
Plate to block are 1/4"NCx1/2".
Pump to plate to block are 3/8"NCx1". Many factory bolts were reduced hex head, makes it a little easier getting a socket in there.
http://store.summitracing.com/egnsea...=KeywordSearch I like the ARP a lot better, Mr. Gasket doesn't have reduced head (and MG is on my "list" for other QC issues as well).
evilstuie
Jan 9, 2020 08:29 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
