I have fuel pressure and spark
Old Apr 25, 2008 | 07:16 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Why wont it start? it wont even sputter or pop?
I need suggestions before I tear out the brand new engine
thank you
Jeff
Old Apr 25, 2008 | 07:21 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: I have fuel pressure and spark
check the firing order or the timing on the distibuter
Old Apr 25, 2008 | 07:35 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Are the injectors pulsing?
Old Apr 25, 2008 | 09:59 PM
jjlabinski's Avatar
Engine: shinny 350
I put a noid on the number one injector harness and it flashed when I turned the key
Old Apr 25, 2008 | 10:26 PM
jem1975w's Avatar
pull gas cap off and try to start could possabley have vaper lock
check compression to
Old Apr 26, 2008 | 01:28 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Unless I'm mistaken, vapor lock is a phenomenon only possible on an engine with a mechanical pump and a carb.
92camaroJoe
Jul 29, 2023 07:57 PM
mdtoren
Aug 23, 2015 12:52 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
