Overheated, what to check?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I had a belt break tonight and overheated the car, for only a couple miles. Had the coolant blow all over the place from the overflow can and such.
It was only for a couple miles before i noticed, and it wasnt running like that long, do you think i could have damaged anything? what should i check? I was going to drain the oil, pull the plugs and see of the motor holds water. Anything else? Im freaking out right now and i cant think straight, im terrified that i may have F-ed up my motor!
Help!!!!!
Help!!!!!
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Overheated, what to check?
first thing to check is the oil, see if any coolant mixed with it. From there I'd do a cooling system pressure check. Next would be a compression check. Where do you live in central jersey? I'm in hamilton.
ah cool your a little south of me. hope everything is ok!
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Dude, I'm not a master mechanic, but it sounds like your water pump stopped pumping because the belt was gone, and your coolant was not running through the system, and your car simply overheated because of this.
I would replace the belt and run your car.
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
then post and tell us how it's running if you haven't done so already.
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Do an oil change just to be safe and look for coolant in your oil, if it looks ok then put a new belt on and run the car.Hopefully you didn't blow a head gasket.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by //<86TA>\\
I had a belt break tonight and overheated the car, for only a couple miles. Had the coolant blow all over the place from the overflow can and such. It was only for a couple miles before i noticed, and it wasnt running like that long, do you think i could have damaged anything? what should i check? I was going to drain the oil, pull the plugs and see of the motor holds water. Anything else? Im freaking out right now and i cant think straight, im terrified that i may have F-ed up my motor! Help!!!!!
Car: 86 Trans Am
Saturday i pulled plugs, checked the oil, and everything looked fine, topped off the coolant and it started up no problems, no smoke/steam ect. Ran for a while and had to foam in the oil so i think im good.
thanks guys
serpentine? why? its just more clutter
Last edited by //<86TA>\\; Apr 27, 2008 at 01:13 PM. Reason: Automerged Doublepost
i turned it off and you could hear it boiling, so i think it was really up there....
Car: 86 Trans Am
Normally 50/50 mixtures (depending on concentration, of course) of water and ethylene glycol antifreeze in the cooling system will boil at 225 degrees when exposed, but as long as the system is sealed and holding pressure, boiling temperature is raised up to 265 degrees, depending on the cap's rated psi. It's hard to say in your case, as you were moving, coolant was spewing, and it all happened within a matter of minutes. Did the engine stall? Was the engine straining to turn over (if it stalled) when trying to re-start (piston seizure)? Did you check for any burnt crud in the oil....?
heres what happened, the car made a clunk noise before i got onto the flemington circle, right in front of wendys, that was the belt coming off, i didnt realize it at the time, and a couple seconds later i noticed it had stalled, at that point i was right on the circle. It wouldnt start right up, but it did not strain to crank, just would not fire. this does happen sometimes when its hot, i think it have a small vapor lock issue. It started up about 30 seconds later, and at that time is was not overheated, then a couple miles down the road is when I found it overheating and shut it down.
I didnt drain the oil, but its fine on the dipstick, should i drain it?
and like i said it was running saturday afternoon with no problems
^ For peace of mind I would drain it, this would eliminate any possible burnt/sludge buildup, eventually causing inadequate oil to the cam bearings. From your description though, it honestly sounds like your fine. When the heck are you planning to join us over at e-town one Friday night with that thing.....?
Car: 86 Trans Am
, and get the rear tire clearance figured out. Do you frequent e-town most fridays? since the weather is getting better and the car is starting to be in working order, i may go sometime soon
BumpaD82
Feb 26, 2016 02:57 PM
