Valve Lash With Compression Gauge?
Old Apr 28, 2008 | 06:43 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
How does one go about adjusting valve lash with a compression gauge, i understand the concept but how are you able to crank the engine with the fuel assembly removed?
I don't believe turning it with a socket will get ya anywhere..
am i suppose to pop the fuel pump/ecm fuse? and re-install my alternator?
i did a head job on my car, i got spark, and fuel but only 70 PSI of pressure at #1 cylinder, didn't check the rest but im sure my valve lash adjustment is out of wack.
Old Apr 28, 2008 | 08:16 PM
Damon's Avatar
Re: Valve Lash With Compression Gauge?
I wouldn't do it that way. Just as easy to crank it over to TDC, compression for that cylinder and set them both 1/2 turn down from zero lash. Then you're not guessing based on compression readings (or lack thereof).
gixxer92
Sep 1, 2015 04:32 PM
R3500
Aug 17, 2015 12:16 PM
cstrobel65
Aug 15, 2015 10:19 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
