how much hp for a vortec 327
Old Apr 30, 2008 | 03:20 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I need a guess on HP for a carbed 9 to 1 compression 327 with vortec heads. It will use a cam with 204*,214* .420",.442".
Old Apr 30, 2008 | 03:54 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: how much hp for a vortec 327
200HP 230FTlbs...
Old Apr 30, 2008 | 04:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Maybe 225HP if you're lucky. Probably more torque then that though, 300ftlbs. That compression, heads, and cam and displacement should be able to sneak up to 300fltbs.
That's a really mild cam, mild compression and tame cubes. Good S-10 "get around town" type of engine. Towing your light boat or something...
Old Apr 30, 2008 | 07:28 PM
discostu's Avatar
DD2k reports the following:
316hp @ 5000rpm and 370ft-lbs @ 3500rpm
So correct for about 10% loss from your accessories:
284hp @ 5000rpm and 333ft-lbs @ 3500rpm at the flywheel
About 30hp better then a stock Vortec 350.
http://i183.photobucket.com/albums/x...tupics/327.jpg
Old Apr 30, 2008 | 08:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why so little compression? Those heads LOVE compression - boost your power and fuel economy at the same time. Kick it up to 9.75 or 10:1 and get a slightly bigger cam and you'd be way better off. Even with a still reasonably tame cam, like the LT4 stock or LT4 hotcam or something similar in size (between 210-220* duration at .050) and you'd do well.
With the combo you listed, 250hp would be optimistic. Change what I suggested and 300hp would be an safe bet.
Old Apr 30, 2008 | 08:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
I would have to argue that one. I know DD is fancy shiny program, but with less cubes and a lesser cam, i'd have a tough time thinking it would make more HP. Less cam meaning a mild flat tappet, vs a peanut roller
Old Apr 30, 2008 | 10:03 PM
discostu's Avatar
The difference comes mainly from the headers. Go back to stock manifolds and the 327 sits at 262hp and 333ft-lbs, which adjusts to 236hp and 300ft-lbs.
FWIW DD simulates both the TBI 350 and Vortec 350 within a couple hp and tq. So I'd say it's close enough.
Old Apr 30, 2008 | 10:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Bing, there we go.
You assume headers though?
Old Apr 30, 2008 | 11:18 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I should have said it will have 1 5/8 longtube headers. I was thinking it would make around 260HP. The cam choice is mild but from what I remember seeing a stock vortec 350 has a milder cam. I can get an extra half point of compression very easily but I dont want to go any higher.
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
