bracket issues...
Old May 6, 2008 | 02:33 PM
89maroconvrs's Avatar
bracket issues...
well i just put a 350 out of a 79 camaro in my 89 and i started putting the brackets for the powersteering and alt. on today. I know i need a new water pump because the 79 pump sticks out farther than the 89. Also i put the bracket on adn the bolt holes wont line up on the bottom of the block and the power wire that bolts onto the back of the alt. hits my valve cover. so do i need new valve covers? the ones i have are not tall valve covers they are short.
Old May 6, 2008 | 05:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your original '89 engine was a V8, correct?
Are you not using the '89 brackets and accessories?
The '79 water pump will be "standard" rotation, and the '89 is "reverse" rotation for the serpentine belt set-up. You need to use the pump that goes with the belt configuration you're using.
Old May 7, 2008 | 12:38 AM
Re: bracket issues...
ya it was a 305 and im using the ones that were on the 305 for my 350. so if i get a water pump for the 305 will it fit on the 350?
Old May 7, 2008 | 02:16 AM
five7kid's Avatar
Yes, they are the same thing.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
