1990 camaro V6 rough idle and hesitation
Old May 9, 2008 | 12:18 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. My brother bought a 90 camaro 3.1 V6 auto, and it has a rough idle and feels like it has no power. Smells pretty rich when standing near it. I pulled the vacuum hose off the regulator and the idle didn't change whatsoever. Someone told me if it was a bad reg, fuel would come out the vacuum port, but I have never heard this. It also has the crap bosch plus 2 plugs in it which will be getting changed. I tried seafoaming it and it didn't help. Any ideas?
A reg cant be that expensive, and neither are the plugs so I may replace both anyways and see if it runs better. No SES light either, and it does work. Anyone have any ideas?
Old May 10, 2008 | 12:58 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
Transmission: MB1 5spd
Re: 1990 camaro V6 rough idle and hesitation
Hey, I just wrote a full page, and the site said I wasn't logging in (I was) and I lost the whole freakin' thing
Instead of trying to remember and re-write the whole thing, just look for my threads I started, esp. the one "Hesitation in 3.1L 5 Spd" from 2006.
I'd start with the injectors, they may be close to plugging the cat now.
The regulator probably is not the problem, get a cheap fuel pressure gauge (about $35.00 at Kragen) to verify. Should be around 38psi at idle (high vacuum) and 47psi with no vacuum. I completely plugged the return line giving the fuel rail 70 psi just to see what would happen, did not run rich at all (this after replacing the injectors).
Good luck!!!
Bob
db057
Jan 10, 2020 08:55 PM
Fireslash
Apr 11, 2016 06:43 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Luigytico09
Oct 1, 2015 08:46 AM
amcnellis
Sep 16, 2015 04:16 PM
