What should be my next MODS!
Old May 16, 2008 | 09:52 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I want to hear some of your guys opinons! I want to do more but i want more ideas name anything you can think that i would like.
I was thinking of shift kit.
  1. Then about a 3:42 or 3:73 posi.
  2. Then put headers on.
  3. Then the 350.
But i want more ideas.
thanks
kevin
Old May 16, 2008 | 10:12 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: What should be my next MODS!
go with 3:73 gears i have 4:10, theyre just too low. i run out of gear too quick.adj. torque arm, drive shaft loop, adj. lower control arms port base, runners, plenum.more to come, later jimmy
Old May 16, 2008 | 10:38 PM
Hey man thanks alot for the ideas!
  1. Now putting in the 3:73 can i still use my same rear end? If so how much do you think it will cost? If i cant use my same rear end how much will it cost?
  2. Then i dont really know what runners, plenum, and the drive shaft loop is if you can explane each one.
kevin
Old May 16, 2008 | 10:56 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
hey man my bad ,you have tbi,not tpi sorry. gears should run around $200.00 bucks or so. going from 2:73 to 3:73, youll have to run a thick ring gear or a ring gear spacer. the drive shaft loop is a loop the drive shaft fits thru, if the shaft u-joint breaks it keeps the shaft inside the loop and from hitting the road,or exhaust pipes, or e-brake cables ,or the vehicle following you.
Old May 16, 2008 | 10:58 PM
So i can use my same rear end? Then right now its not posi so what else do i need?
Old May 16, 2008 | 11:09 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
you can go to a junkyard and pick up a posi rear for a few hundred bucks, may even find one with 3:42 or 3:73 gears.look on here for engine/drivetrain parts for sale forum,they have gearsets and rear ends for sale.later jimmy
Old May 17, 2008 | 05:58 AM
If i do find one most likely it will need to be redone? But if its cheaper i will do it how much would it cos to rebuild one?
thanks
kevin
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
