Fuel Pump
Old May 17, 2008 | 12:20 PM
rebfirechicken's Avatar
Fuel Pump
So I just picked up an 86 mpfi 2.8 firechicken, and there's no fuel getting to the motor. Can anyone tell me where the fuel pump inline fuse is ?
Old May 17, 2008 | 01:23 PM
Vader's Avatar
Re: Fuel Pump
Welcome Aboard!
Look next to the battery:
Or on a V-6, it MIGHT be in the fuse panel:
If the "Check Engine" light turns on with teh ignition switch, the fuse is probably good, since it also powers the ECM. If that's the case, make sure the fuel pump relay is operating.
Old May 19, 2008 | 11:33 PM
Re: Fuel Pump
thanks, the check engine light goes on, so I'll check the relay
Old May 20, 2008 | 02:26 AM
samzch8's Avatar
Car: 88 Iroc Vert
Engine: 5.0 TBI
Transmission: 700R4 w/shift kit
Re: Fuel Pump
I just went through diagnosing my fuel pump as bad. In the process of taking stuff apart now. This thing is a pain in the ***. Good thing i got under here though, found the drivers rear caliper leaking . Good luck. And if you check the wiring leads to the fuel pump (flip the rear seat back down) the red is for the prime lead, and tan/white is the run lead. Oh, and dont forget the ground.
Old May 24, 2008 | 02:54 PM
Oklahoma86's Avatar
Re: Fuel Pump
How do you check the fuel pump relay to make sure it is operating correctly? I'm having the same sort of problem.
I tried to start the engine many times before realizing that my tank was bone dry. I remember hearing the hum of the fuel pump early on. But now there's no fuel pump sound. I'm hoping I didn't burn out the pump. But I need to check the in line fuse as well as the relay. Any advice on the relay would be great.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
