NEED HELP!!! QUICK!!!!
Old May 19, 2008 | 05:34 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
TRYING TO CHANGE FUEL PUMP!! CANT REMOVE GAS TANK!!! TOOK OFF BASICALLY EVERYTHING. SHOCKS ARE LOOSE, REMOVED SPRINGS, TANK STAPS.... IT JUST SEEMS LIKE THE GAS TANK NECK IS TOO LONG. I JUST CANT ANGLE IT TO COME OUT WITHOUT THE NECK HITTING THE BODY!! WHAT NEXT??????????
Old May 19, 2008 | 05:48 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: NEED HELP!!! QUICK!!!!
You got to tweak it just a little. When the tank is dropped down as far as it will go and is turned to where it is hitting the inner fender lip and pan hard bar mount start pulling it downwards in very short bursts. You will feel the neck bending ever so sligthly. Keep jockeying it, it will come out.
When you go to re-install it you will need to pull up on the filler neck to put it back to its original position. If you dont get it exact it will not be noticable when you put the bezzle back in the fuel door area.
This is how I did it in my 84
Jeff
Old May 20, 2008 | 07:24 AM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
earm.. cut it and get a new tank sorry. ill think about it during the day and reply if i think of a more logical way of doing it.
but easy on the caps fella.
Good luck man
-Andrew
Old May 20, 2008 | 04:46 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Axle/Gears: 2.77
Good luck man
-Andrew
HA-HA.. yeah I'll think about MAN!?!?!?! What the hell is that? Never mind dude.... GO EASY ON THE SMILEY FACES!
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
