Z06 springs
Old May 21, 2008 | 11:48 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Z06 springs
I found a set of stock Z06 valve springs on sdparts,
http://www.sdparts.com/product/12499...ringSet16.aspx
would these springs work on regular gm heads without machine work?
thanks
Old May 23, 2008 | 12:51 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Z06 springs
Depends on what heads.... For an LS1, maybe. For an LT, vortec, or earlier it would be better to buy the right springs.
Old May 24, 2008 | 12:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Z06 springs
Hmm, price is right for the specs.
Height measurements seem right.
See if you can find out what the ID and OD of them are. It says it's a good replacement for LS1 springs, so anyone know offhand what ID and OD those are?
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Dragonsys
Sep 25, 2015 03:51 PM
