Speedo cable or something else?
Old May 28, 2008 | 12:11 AM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
Hey guys Im new to the forums. I just bought a 92 RS 25th anniversary and the previous owner broke the speedo. It works sometimes when you get on it but when it does work it seems to shift much better. Its an automatic by the way. Id like to at least get an idea on what to do before I start buying things and find out that wasnt the problem. Help?
Old May 28, 2008 | 12:34 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: Speedo cable or something else?
If I remember correctly, you don't have a shift cable. That car should have an electronic speedometer. Check the wiring going to the tailshaft of the tramsmission to be sure you don't have damaged wires or connector.
Sometime it works, sometimes it don't sounds like a connection problem.
Last edited by DSmith; May 28, 2008 at 07:48 AM. Reason: LOL I put shift cable, meant speedometer cable
Old May 28, 2008 | 12:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by DSmith
If I remember correctly, you don't have a shift cable...
I'm sure you meant "speedometer cable".
Anyway, I agree. Bad VSS would make the ECM wander a bit.
Old May 28, 2008 | 07:46 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Darn Five7, I did do that didn't I. LOL! Too many hours without sleep will sure mess up the mind.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
