A/C Fan weak
Old Jun 5, 2008 | 09:33 AM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Transmission: Manual
A/C Fan weak
my 87 TA has the push-button semi digital air conditioning. The air is cold but the fan seems weak. I have checked and of the 4 settings only 2 work. speeds 1 and 2 are dead. 3 shows a little airflow and 4 is what I would expect 2 to be. Does anyone have a wiring diagram so I can try jumping out the wires at the AC head and the relay.... to try to narrow this down? I suspect this system works kind of like a 3 way light bulb but I can not quite figure it out? Is it voltage modulated or are there multiple sets of coils that are triggered to increase fan speed.
-todd
Old Jun 5, 2008 | 06:39 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Re: A/C Fan weak
I spoke to the guy at the auto Parts store and I was told that the resistor controls the speed. Is this correct? Anyone know how? is it increased voltage?
Old Jun 6, 2008 | 04:22 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: A/C Fan weak
There's a "resistor" thing in the blower box, under the hood. Its got three or four resistors in it, that control the different fan speeds. They're probably not what you'd expect a resistor to look like though, they're just different size wire coils. I haven't had to change one yet, I'm not sure exactly where on the box it's located, but pretty much all GM cars have it there somewhere. Looks like this (the wire coils will be hidden from view, inside the box):
Old Jun 6, 2008 | 06:39 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: A/C Fan weak
The resistors control the speed of the fan for the first three, lower speeds. At high the power goes straight to the fan, no resistor. If your fan is running low at all speeds, it's likely the fan motor not the controller. A replacement fan is like $15-16 at AZ. Try jumping a hot wire directly to the fan. If it runs the same, slow speed as the 'high' position you'll know it's the fan.
Old Jun 6, 2008 | 05:57 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Re: A/C Fan weak
Thanks guys ... I have owned mostly Ford and one Plymouth. I amazed at how different the GM is. I definitely have an uphill learning curve but I love the fact that GM re-uses parts from stock. Ford changes everything constantly making it a nightmare to comb the boneyard for parts.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
lanceflame44
Sep 25, 2015 12:28 PM
