Vacuum Hose that goes nowhere!
Old Jun 5, 2008 | 10:06 PM
69-Camaro's Avatar
Up by the cruise control ther are vacuum hoses. They have a t-fitting and the one that comes off at 90 degrees, where does it go? It has vacuum on it and it is just laying there? Does anyone know? I have looked and cannot find an open port? If you need more info or pics let me know?
Sorry, this is on a 1990 Iroc Convertible.
Old Jun 6, 2008 | 04:19 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Vacuum Hose that goes nowhere!
Possibly the charcoal canister?
Old Jun 6, 2008 | 05:05 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Pics and the engine size and type would help. I can post you a full vacuum diagram if I knwo the engine type. Also, as Ward suggeste, I'm thinking it's the charcoal canister you're talking about, but pics would help...
Old Jun 6, 2008 | 06:09 AM
69-Camaro's Avatar
Found the issue. Now if someone knows what this is? It is from the top of what looks like a canister up by the cruise control. Also it is a 1990 305 tpi. Here are some pics of the broken (what I think is a vacuum purge regulator???)
Attached Thumbnails Vacuum Hose that goes nowhere!-p1000217.jpg   Vacuum Hose that goes nowhere!-p1000218.jpg   Vacuum Hose that goes nowhere!-p1000219.jpg
Old Jun 6, 2008 | 07:08 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
It is a purge valve solenoid, but not for vacuum. That canister is taking the fumes from the gas in your tank, and storing them in that canister and then when commanded by the computer, it's opening the valve and burning the fuel. It saves you a little bit on your mileage.
Here's the vacuum diagram for your engine, if you still need it.
File Type: pdf
Old Jun 6, 2008 | 07:12 AM
69-Camaro's Avatar
Is this part available? Do I have to purchase the entire canister assembly? This could explain the rough idle and what smells like light flooding.
Old Jun 7, 2008 | 05:05 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Hi,
Did You find where that vacuum hose should connect? Have been asking the same question on this forum...
regards
Hasse
Old Jun 7, 2008 | 08:06 PM
Damon's Avatar
One end goes to the cruise control and the other goes to the Vacuum Reserve Chamber (the round plastic ball inside the driver's fender). It's different from the charcoal canister, which is an emissions device. The vacuum reserve chamber stores a little vacuum to run the HVAC control valves and servos under the dash and the cruise control vacuum servo during brief periods of low engine vacuum (like when you go to wide open throttle, for example).
Old Jun 8, 2008 | 12:11 AM
69-Camaro's Avatar
My car does not have the ball? It goes to a dead port on the purge regulator. I just capped it off and went on my way. No problems and everything works fine.
Old Aug 6, 2008 | 01:02 AM
mercdeking's Avatar
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
Now the search function got me where I was looking at, I found that same t with a hose that goes nowhere. Now to go to the junkyard and look for that ball. Not sure why but eh, maybe I'll find the next thing I'm looking for which is some nice replacement seats for my camaro.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
