timing tab question
Old Jun 6, 2008 | 04:45 PM
speedped79's Avatar
Car: 1982 z28
timing tab question
its a 91 350 out of a caddy, roller motor, i have a msd 6al setup and it has a holly 650, ive been having issues with it since day 1. i bought a aftermarket chrome timing tab, it bolts in the same location as the stock one, but my question is, when i had the motor at tdc on the stand the mark on the balancer was a good 1/2 inch away from the nearest mark on the tab, what could cause this? i need to time the motor but am not sure about the tab, also what is the factory setting? its a 91 350 from a caddy fleetwood broughamthanks steve
Old Jun 6, 2008 | 05:52 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: timing tab question
there are different timing tabs for chevy engines.
each tab goes with a certain size crank dampner.
you have to measure the dampner.
also if the tab IS the correct one.
the outside ring on the dampner could have shifted.
check that out.
midge54
Dec 27, 2019 04:14 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
