tire size?
Old Jun 15, 2008 | 06:27 PM
Gregg85IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 5.0L 305 V8
tire size?
so i burst my drivers side front tire, im rolling on 15'' rs rims
could anyone tell me what size i need to replace it?
Old Jun 15, 2008 | 06:53 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: tire size?
stock is 215/65/15
some go with 225/60/15
Old Jun 15, 2008 | 07:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tire size?
or you could just look at the tire you blew, jot down the numbers on it and your set.
Old Jun 16, 2008 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: tire size?
Hey Greg, any mods on your camaro? Can't wait to run into you in town here....
And yea, just read the front right tire. But you'll need to buy two anyway, you can't just replace one (unless it's practically brand new). Might as well get a set of the 235/60/R15 (that's identical height) and put them on the back, and put your ones from the back on the front.
Old Jun 16, 2008 | 06:01 PM
Stephen's Avatar
Car: 87 GTA
Re: tire size?
If 1 is badly worn, a new one on the other side will betalle, and either cause bad steering alignment, or bad tracking on the rear.
Either end, you could be looking at an alignment/steering issue.
Old Jun 17, 2008 | 04:03 PM
89RS_82Z's Avatar
Re: tire size?
i agree
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
