VIN Number HELP!!!!!
Old Jun 17, 2008 | 03:37 AM
DerekZ28's Avatar
Car: 1989 Formula 350
Transmission: 700R4 Auto
Axle/Gears: 3.27 Borg Warner
Hey guys.
Some interesting information on my firebird.
It has 2 VIN numbers. The only one that was not ripped off on the body, located on the rear bumper, reads 1G2FS2189KL258415. This indicates that it is a Firebird Base/Formula 5.7L V8.
The other VIN, on the window sticker is one from a 305 firebird of a different year... a 90's model, and it ends with NY47071.
The engine ID code reads 5.7LG, means its a 350, and the tach redlines at 5500RPM, another indication it is a 350. The body is also from the factory, and appears to be consistent with the VIN located on the rear bumper. The differential stamping reads "Borg Warner" and has a plate that says 3.27 GEAR RATIO. The borg Warner 3.27 Rear is ONLY found on the 350 700r4 cars.
The title VIN reads NY47071. The Yellow sticker in the door reads: "NY47071: Affixed by the state of new york as a replacement plate after examination of this vehicle."
I don't know what the &^$% this is all about. I want to know why the VIN on my Inspection sticker reads that I have a &@%$&*@ 305.
Why would this be??
Old Jun 17, 2008 | 07:51 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: VIN Number HELP!!!!!
i would delete this post and forget about it... there was a long post on here about the police getting involved on a vin dispute. i think that you could get nailed pretty bad if the police got involved.
Old Jun 17, 2008 | 08:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can change the window data plate. You can change the center console to change the RPO data decal. You can change the doors to change the decal on the door but it's difficult to replace all the other vin decals attached to the main part of the body and there are quite a few of them.
There should be a body decal inside the spare tire compartment. There should also be one behind the paneling of the hatch.
I wouldn't trust any decal that's on a part that can be replaced.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
