LWP alternator bracket for a custom app
Old Jun 17, 2008 | 09:05 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Any of you guys, can you think of what I can use for a top bracket/adjuster? I'm running a long vette water pump which does not have top bolt holes for a traditional top bracket, nor does my miniram intake have the top hold that most carb intakes would have. But I need an old style bracket that I can adjust and lock down.
Here is what my water pump looks like:
http://members.cisdi.com/~anesthes/p...ngine-4808.jpg
Right now the alt is sitting in the AC bracket and is locked stationary. I want to replace the bracket with a normal lower bracket, but I have no way to make the top adjustable. The only threaded hole on my water pump is vertical not horizontal like all the brackets I've seen.
Anyone ever seen anything?
-- Joe
Old Jun 17, 2008 | 10:44 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: LWP alternator bracket for a custom app
go to www.summitracing.com put in #sum-420100 $64.95 the bracket with the adjustable ends should work great, thats a sweeeeet azzz engine , later jimmy
Old Jun 18, 2008 | 07:31 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi Jimmy,
Thanks! And I was looking at that hit, but I don't know where I'd mount the adjuster as I don't have that style water pump...?
-- Joe
Old Jun 18, 2008 | 02:40 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
try this www.marchperf.com see if any of those will work,later jimmy
Hotrodboba400
Dec 10, 2019 07:07 PM
L0tuS
Oct 4, 2015 08:07 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
