6 Inch Connecting Rods
Old Jun 19, 2008 | 01:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm posting this for general information. On researching my new short block I have found out that when going to a 6 inch rod the total piston/rod weight is reduced. The will aid in the balancing of your motor and the force applied to the crankshaft at higher rpms.
Also something else I did not know. I was playing with my dynamic compression ratio calculator and with the 6 inch rod at least in my case it lowers the DCR slightly. In my case that is a good thing.
I'm shooting for a static compression ratio of 11.00:1 and a DCR of 8.5:1. Well with the 6 inch rod it brought in the DCR right at 8.51:1 with my target 11.00:1 compression ratio. With the 5.7 inch rod the DCR was a little higher at 8.55:1.
Also the rod angle is a little better with the 6 inch rod. Funny on the horsepower. With DynoSim it says I will gain 2 horsepower. However with PipeMax it says I will loose two horsepower. I'll just call it even.
Old Jun 19, 2008 | 03:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 6 Inch Connecting Rods
haha, that's pretty standard results when going to a 6" rod. (re: research)
Teeny tiny changes on paper. The actual real world results, well, I think the jury is still out on that. It's such a small difference, I think density altitude, cloud cover, and lunar cycle will have more noticeable effects
Old Jun 20, 2008 | 02:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Allen still thinks he's building a race car engine in a street car body. You'll never be happy Allen, so just go with the 420ci aluminum small block engine.
Old Jun 20, 2008 | 08:32 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
longer rod or stroke= slower reving engine
thats why the 302 that came in the 68 & 9 camaros were so bad ****
Old Jun 20, 2008 | 11:42 AM
Car: 1989 GTA
Engine: 369 TPI
Hey, just taking advantage of the new technology. How did I know my car with TPI would want to rev and make good power into the high 6000rpm range.
Old Jun 20, 2008 | 11:48 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
rod length doesnt effect stroke.
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
