what fuel pump to use
Old Jun 21, 2008 | 02:35 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
i just put in a new fuel pump a Dynapex hp. brand pump no good my fuel presure goes to o psi when i nail the gas. my stock pump was not that bad
so what is a good pump to buy. should i run a stock in tank pump and a exteral pump. its a pain to keep pulling my tank.. my new motor is a 355 with hsr. and aluminum heads. 380hp.
Old Jun 21, 2008 | 02:57 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: what fuel pump to use
rwhp x .5lbs = weight of fuel @WOT. divide by 6 to get the volume and there is your answer as far as flow goes.
i would personally go holley.
Old Jun 21, 2008 | 03:08 PM
400 hp's Avatar
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
well i think i will go with racetronix fuel system kit with wire harness. looks like a nice kit..
http://www.racetronix.com/RX-FL98-FPKG-2.html
Old Jun 21, 2008 | 05:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Holley makes a good fuel pump, as does racetronix.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
