Need help from some one !!!!!!!!!
Old Jun 21, 2008 | 04:30 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
today i decided sence i ditched the computer controled carb and dis i would remove the wires that went to them to clean the engine bay and i removed the comp did i do somthing wronge i also play with my carb now the car strats hard and will turn over but won't stay running.
Old Jun 21, 2008 | 04:52 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Need help from some one !!!!!!!!!
ah lovely warwick... how many wires are going to the dist right now? 2 right?
was the car running before you started playing with the wires? what about some details on the engine? dist that you are running? carb?
Old Jun 21, 2008 | 05:01 PM
RandyZ's Avatar
two from the main harness tech and batt ,vacuum advance dist and qjet from a corvette mech one ,and yes it did run befor disconeting the wires but it does start up after i did take them out too.I did take the carb apart to make shore there was no dirt in it today .you see it always idled funny that why i took off the top.My main concern it i really don't see the wires that i took off doing anything for the motor
Old Jun 21, 2008 | 05:05 PM
Car: 91 RS
Engine: 350 vortec
do you still have an oil pressure sensor hooked up?
