Hows the fitment with MSD underheader wires?
Old Jun 28, 2008 | 09:20 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I was looking at Summit thinking about getting some new spark plug wires before I crank up the HSR. I had a set of cut-to-fit Taylor wires, but I came across these:
http://store.summitracing.com/partde...rsview=sku&Ns=
8.5mm, already assembled, and are made to be routed under the headers, which is what Im looking for. Has anyone got a set of these? Im curious how the fitment is with them, if they actually fit fairly decent or if there's alot of slack in the wires. It'd be a PITA to make a new set of wires, but for double what a set of Taylor's cost it might be better that way. It would be nice to get a set out of the box ready to go for under header mounting
Old Jun 29, 2008 | 10:53 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Hows the fitment with MSD underheader wires?
i've used those wires before on two cars with header installs. they work good, and there is not extra slack. but just like any header/wire install you have to place them so they dont touch.
Old Jun 30, 2008 | 09:48 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I put them under the headers EVERY time
get the universal cut to fit wires and hopefully you do this fitment before you put the motor in because I dont think its worth the hassle if you have to reach around the headers and the firewall while the motor is still in the car
Old Jul 9, 2008 | 02:45 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
so i think im gonna order these. what did u say about universal ones? will these fit, no cutting, no extra slack(reasonable amount)? my motor is in there so i aint takin it out, im gonna have to do it the normal way.
Old Jul 9, 2008 | 03:11 PM
spills's Avatar
Car: 89 RS
I was actually able to reuse my cut-to-fit wires from my first motor build (I went from large cap to small cap dizzy). The cut to fit wires can be a little time consuming, but it's not that complicated if you route the wires properly THEN cut the wires. The more I think about it sicne the car is rarely driven, Id rather cut my own that way I can be sure that it will fit. But that's just me.
I dont think it's that big of a deal that the motor installed if you get the cut to fits. Granted it's easier if the motor is pulled, but it's not impossible when it's installed.
BRoss99
Aug 10, 2025 05:08 PM
toronto formula
Nov 10, 2015 06:17 AM
kah992
Aug 19, 2015 02:55 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
