Nuts for Fuel Tank Straps
Old Jun 30, 2008 | 09:43 PM
vangyzen's Avatar
Car: 1989 IROC-Z
Transmission: 700-R4
Axle/Gears: BW 2.77
In an amazing feat of remarkable idiocy, I have cross-threaded one of the bolts for my fuel tank straps and ruined the nut. Unfortunately, the nut is not just a simple nut; it's built into a clip that holds it in the body/frame.
Does anyone know if my local auto parts store might carry these nuts? (I would ask them myself, but they're already closed today.) Would I have better or worse luck at a GM dealership? Would you happen to know the part number?
Thanks in advance.
Old Jul 1, 2008 | 08:52 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Nuts for Fuel Tank Straps
drill it out and put a nut and bolt combo
Old Jul 1, 2008 | 09:12 AM
vangyzen's Avatar
Car: 1989 IROC-Z
Axle/Gears: BW 2.77
Are you suggesting just using a normal nut? I wish it were that easy. There's no way to get a wrench on a normal nut in that location.
Old Jul 1, 2008 | 12:00 PM
jamon8's Avatar
Engine: 350 tpi
there is always a way
with that attidude just junk it- a little extreame buy maybe you need a wakeup call
Old Jul 1, 2008 | 04:16 PM
vangyzen's Avatar
Car: 1989 IROC-Z
Axle/Gears: BW 2.77
You are way too quick to judge others. Of course there is always a way -- some ways are just more difficult than others. In this case, it turns out I can just pick up GM PN 22531616 from my local dealership. A simple solution to a simple problem. No hacking or fabrication necessary. No frustration or bloody knuckles from trying to do it a more difficult way.
Old Jul 1, 2008 | 10:01 PM
jamon8's Avatar
Engine: 350 tpi
your right
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
