Starting issues solved!
Old Jul 3, 2008 | 04:41 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
For the past 3 months, I have been plagued by the infamous problem of a car that won't start, even though the battery in the car will start another car. New battery, new starter, new cables (they were all onld- gave me an excuse to upgrade) didn't help it at all. After much head scratching and even more cussing, I found 2 problems in the starting circuit.
#1 Water had leaked into the car from a previously repaired leaking T-Top seal, and had caused corrosion in the starter enable relay located in the drivers side kick panel (this will only apply for '89 - '92 F-Bodies with VATS). This was not a huge problem, but it did add a few ohms of resistance.
#2 The ignition switch. Everyone has at one point or another suffered a case of the floppy steering column. This play in the column can actually cause the igition switch to be out of adjustment (Yes there is an adjustment). A combination of age (resulting in a significant resistance increase in the switch) and the floppy column (that I finally got the tool to repair properly) had damaged the switch.
Once I made these repairs, the car starts like it did when it was new.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
